This might involve checking out a copy from
a repository with subversion (svn) or git.
eg git clone
or retrieving a compressed archive (.tar.gz, .tgz, .zip)
from a web site.
Decide where the source code will be located once it
has been retrieved and extracted.
eg $HOME/src
Within that directory either check out a copy of the source code
cd $HOME/src
git clone https://github.com/example_pkg/example_pkg.git
or extract the source code from the downloaded archive
cd $HOME/src
wget https://mirror.aarnet.edu.au/pub/gnu/bison/bison-3.0.4.tar.gz
tar -z -x -f bison-3.0.4.tar.gz
(Replace -z with -j for .tar.bz2 and --xz for .tar.xz compressed archives)
Since its release the package may have accumulated a number of fixes and small features available as patch files.
Retrieve any desirable or applicable patches.
cd $HOME/patches/example_pkg
wget http://www.example.org/example_pkg/example_pkg-fixes-1.patch
Apply the patch(es) to the source tree.
cd $HOME/src/example_pkg
patch -p1 < $HOME/patches/example_pkg/example_pkg-fixes-1.patch
While not all packages support building outside the source tree this is best practice. In this case you create a working directory separate from the source directory under which you will build the application. Your source tree is then left untouched.
mkdir -p ${HOME}/work/bison-3.0.4
Where this is not supported your working directory will be the source directory.
If the autoconf tool set was used to prepare the package there will be a shell script configure in the source directory. This script will accept command line parameters that specify where the final components will be installed, enable or disable various optional features.
You will invoke this script from the work directory
cd ${HOME}/work/bison-3.0.4
# List what features and options are available #sh ${HOME}/src/bison-3.0.4/configure --help
At this point you will have to decide where the resulting executables, libraries and configuration files will be installed.
mkdir -p ${HOME}/gnu/bison-3.0.4
For simple installs everything can be place under one directory specified by the --prefix parameter.
sh ${HOME}/src/bison-3.0.4/configure --prefix=$HOME/gnu/bison-3.0.4
For finer control the locations of the executables, libraries, configuration files and volatile files can be individually specified. See the output of --help
The configure script will symlink the files in the source tree into the work directories and output Makefiles under the work directories. Once this process has successfully completed, the build can begin by invoking make
make
There will usually be a number of warning messages from the compiler but hopefully the build will complete successfully.
Many packages include a test suite that may be invoked after building.
make tests
To install the executables, libraries, configuration files and documentation into the location specified earlier during the configure phase—
make install
To remove the intermediate and temporary files required to construct the software—
make clean
To return the to the source tree to its original (patched) state before the configure phase—
make distclean
If your software has been installed under $HOME/gnu/bison-3.0.4
then the executables will be found under $HOME/gnu/bison-3.0.4/bin
To invoke the executable you can specify the full path
$HOME/gnu/bison-3.0.4/bin/bison -y gram.y
More conveniently you can add $HOME/gnu/bison-3.0.4/bin to your PATH
setenv PATH ${PATH}:$HOME/gnu/bison-3.0.4/bin
If you have many such packages it may be more convenient to install
every package under the same directory— here perhaps $HOME/gnu —
then all the executables from each package will found under $HOME/gnu/bin
Then only one addition need be made to the PATH variable.
Alternatively you can still install each package (and different versions of)
under its own directory but symbolically link each executable from the
install bin/ directory into a common bin directory—
typically $HOME/bin
which is usually included in your PATH
cd $HOME/bin
ln -s ../gnu/bison-3.0.4/bin/bison .
rehash
To make the addition to your PATH permanent ‐ edit your .cshrc file to include your bin directories in your PATH
# Edit .cshrcnano ~/.cshrc
# Add to the end of the file - skip if already done.if ( ! $?_HOME_BIN ) then
setenv $_HOME_BIN ${HOME}/bin
setenv PATH ${PATH}:${_HOME_BIN}
endif
